G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Interior & Exterior (https://g35driver.com/forums/interior-exterior-21/)
-   -   I Can't Stand the Clearance Light...Any way to disconnect? (https://g35driver.com/forums/interior-exterior/54633-i-cant-stand-clearance-light-any-way-disconnect.html)
Sundeviljay May 19, 2005 01:11 PM
I cannot stand the clearance light...it does not match any of the other lights on the headlight or the sidemarkers...is there an easy way to disconnect just the clearance light? I would rather not have it at all...Anyone have info on how to get to the connection and which connection to un-plug?
TheKnite May 19, 2005 01:19 PM
Bulb
Just take the bulb out.
Sundeviljay May 19, 2005 02:43 PM
Right...how do I get to it though?
S-Tuned May 19, 2005 02:55 PM
1. if you want to take it out do a search on the boards
2. you can make it match with PIAA bulbs
G6MT May 19, 2005 03:20 PM
There are plenty of posts in the MOD section that deal directly with this issue. Once you find the perfect set-up you'll def like the look. ;)
Sundeviljay May 19, 2005 03:24 PM
Am I the only one? I just think it would look better w/just the headlight and the turn sig on...disconnect the clearance for good...I guess I will just have to try it out...I'll do a search to see how to get to the headlight...hope it isn't too hard.
Asianicboi May 19, 2005 03:50 PM
it's not too hard, ujust gotta jack up your car and take a couple screws out, flip open the panel and reach in to disconnect the bulb
Sundeviljay May 19, 2005 03:54 PM
Sheeeeeite that sounds like a pain...I don't even have a jack
sporting35 May 19, 2005 04:07 PM
if you don't want to jack it up just try going through the wheel well..i'm assuming you can access the light by just detaching some of the pop out screws in the wheel well...just remember to turn your wheel to the inside so you have clearence to pull out the molding
Silverbolt May 19, 2005 04:32 PM
Didnt your G35 come with a little jack?
pdjafari May 19, 2005 04:57 PM
dont need a jack to do it...simply turn the steering whel in the completely opposite way from the side you want to remove the bulb from....remove the inner fender paneling and voila! personally i love the clearance light though.....
skeleton_cru May 20, 2005 06:41 AM
Am I the only one?
Yes.
Asianicboi May 20, 2005 12:34 PM
Originally Posted by skeleton_cru
Yes.
^ lol
WhiteonWheat May 20, 2005 02:28 PM
I'm glad you all are talking about this, b/c I was just thinking about it last night.
Personally I would like it to match the *AMBER* aka Orange parking lights and marker lights.
What in the world is this "Clearance Light" supposed to be function wise??
Is it really that difficult to change out the clear bulb to an amber bulb or a PIAA bulb? (Jacking the car up /or/ turning the wheel inside and yanking parts of the car off to get to it.
YIKES!!
Anyone have some pictures of "How To"??
In the other car forum that I belong to we have a "HOW TO" section where members can post detail lists (with or without pictures) of how to do mod's. Really helps the non-car "Savy" people out. If I do any Mod's, I plan on doing a full write up with Pictures. We all should do that or try to. Really helps out!
skeleton_cru May 20, 2005 03:18 PM
That's a great idea! It took me several hours but I managed to create a section called "FAQ & DIY" short for Frequently Asked Questions and Do It Yourself. Thanks for the idea WhiteonWheat, I hope it meets with your approval. :D
https://g35driver.com/forums/faq-diy-11/
© 2026 MH Sub I, LLC dba Internet Brands
