Help removing driver's seat
I have an 03 coupe and I need anyone's help who has removed their front seat. So the reason I'm doing this is because I need to tighten the seat down since the right side of the seat seems to have come off it's base. So if anyone can tell me where the screws are to do this, and what not that would be great. I have an idea where to start, but considering it's electric anyone who's done it, that can point me in the right direction would be great.
it's actually really easy to do. there's only 4 bolts that hold the seat down and they all have plastic cover on them. just remove the plastic cover and loosen the bolts with a socket wrench. there's two in the front, one on each track, and two in the back on each track.
be careful if you take the seat completely out, because you'll have to disconnect the wires (also really easy) for the air bag, seat heaters, and adjusters. that's just 1 clip for all of them that pops right out. you'll actually be really surprise on how easy it is to remove the seats, i know i was. hope that helps. |
^what he said....14mm bolts x4
If you're thinking about disconnecting the wiring, disconnect the negative wire on your battery first. If not, you'll get the airbag light when you plug everything back in. |
i would just leave the driver seat in...you might need it.
Thanks guys for all the information. I just wanted to see where they were and to take it out to see what might need to be tightened. Yes, I plan on putting the seat back in, because I will need it.
| All times are GMT -4. The time now is 02:32 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
