everything electronic doesn't work on my steering wheel...
Old May 15, 2011 | 06:10 PM
G35Bandit's Avatar
airbag, horn, cruise control and music controls. I finally took it apart and figured out what the problem is but I have no clue how to fix it or replace it.
There is a spiral connector that apparently decided to come disconnected. I tried soddering but no dice. Any suggestions? (this couldnt have happened at a worse time because I have state inspection due this month and they wont pass you with an airbag light =/
Old Jun 2, 2011 | 02:21 PM
beniscooler850's Avatar
have you fixed this yet
Old Jun 2, 2011 | 04:17 PM
G35Bandit's Avatar
Yes, I toook my entire steering wheel apart to find that there is a tiny strip of flat wires (kinda like a serial cable flattened) and it spirals with the wheel, but it had snapped from the wheel turning to far (my own dumb fault)...anywho if it turns out that you need a replacement, I've only found one place and its 126 dollars because you can only buy the assembly
Old Jun 3, 2011 | 10:34 PM
cool thanks my dumb fault as well i took out the steering in my car when i was changing the headers then told my friend to turn the wheel for some reason i dont know why and i guess he turned it too many times thanks again for the help
kd03g99
Jul 30, 2015 11:24 AM
newg37
Jul 26, 2015 09:32 AM
beevanhuynh
Jul 14, 2015 09:06 AM
