WTB: Nismo Ti Shift knob 6sp STICKER
Thanks, I'm slowing starting to realize that haha - I got quoted 50$ by a local trophy shop to engrave a little piece of aluminum, but looking into it more I'm pretty sure the 5sp sticker that's on there is plastic, so I'm going to start looking down that route to see how much it is. I do have access to a laser etch machine that can cut plastic, just gotta find the shiny stuff and figure out how to paint that tinyass R haha. Still not quite sure how to remove the 5sp piece on there now, probably end up destroying it in the process of removal anyways so I'm considering just drilling it out in the center. Looking up from the bottom of the **** there's a phillips head screw, but once it's loose It doesn't seem to fit through the plastic - might just be securing a weight in to the top?
The round 5 speed shift plate is of very thin metal maybe aluminum, titanium? idk but its quite simple to remove. Just boil some water and then dip the top of the shift **** into it and leave it there for 2-3 minutes to soften the adhesive and with a needle or something very thin begin slowly prying the round shift plate up and it should come off. This is the method I used to restore my Titanium Nismo ****.
Tried the boiling water trick and it worked! Since the PO had already scuffed up the insert I didn't mind doing more damage, and was finally able to press one side down hard enough to pop the other side up, then get a razor blade under it and pry it off. Turns out it is actually aluminum, so I'm back to square one on trying to diy a 6sp version. I have access to a 3d printer, but I don't think it can do this kind of small detail - looking into a small lost wax casting setup?
JG_G35 (01-17-2019)
I might have a solution for you depending if you are willing to purchase another shift **** and getting it refinished at a shop that can make the diameter of the NISMO **** wider. Or just put it on top if you dont mind it protruding.
I got a Top Secret Shift **** from Nengun. The sticker that comes with it is slightly bigger than the NISMO aluminum plate. But in all honesty, I think this looks amazing. The black in the logo really pops.
Might buy a used up Nismo shifter and get it refinished to fit this sticker.
Thanks for the heads up, at this point I'm going down the DIY route, bought a couple rounds of Al and have a buddy with a janky old lathe to cut off a little disc (Ø22mm x 0.5mm), and another with access to a fiber laser to etch the shift pattern. Working on recreating the pattern now, might make a few extra and post them up for sale if anyone is interested.
Haha woulda coulda shoulda, but I'm too deep down the rabbit hole now.*
Worth a try lol.*
Let us know how it turns out, I'll pick one up for a just in case!
I got the discs cut this weekend - they look pretty good off the lathe but still want to give them a polish, and I don't have a timeline on engraving as I still need to work on the designs.
I have 5 insert pieces to play with, so I might give DIY ano a try. I was looking in to additive etching as well but the coating required is a bit out of the price range of this little project.
any update on the final product?
