Need 2006 Infiniti G35 Coupe Driver's Front Seat/Bottom
Hi
I live in Louisiana and my front bottom only driver's side seat has torn in numerous places. It does have heated seats, air bag, etc. Would I be better off replacing entire bottom seat or is it a fairly easy project for someone to put the leather on the seat, if I can find someone selling leather in decent condition? Any suggestions, anyone have either one for sale...I'm just a gurl, so i have no clue what goes into putting leather onto the seat vs replacing entire seat. Any and all comments will be appreciated. I have very low mileage 69K, and this is the only thing that is wrong, besides the dashboard, I am seeing minor cracks.... |
Moving your thread out of the marketplace / sale threads since you aren't selling anything :)
You should check around with local auto upholstery shops and get a quote on having the seat repaired, if they keep the existing foam it's usually only a couple hundred for full leather on the bottom. If you don't know who the local auto upholstery shops are call your local hot rod / tuner shops and see who they recommend. The hot rod guys ALWAYS have an upholstery shop they recommend. |
I have went to lots of Upholstery shops, but they did not have the material with the holes in it for the heated seats, but will check with "Hot Rod Guys" to see who they recommend....Thanx for the quick reply :)
Thanx, the last time I tried to do so, most of the leather upholstery shops did not have the leather w/the holes for the heat, but I will check with the "Hot Rod Guys" and see who they recommend.
I'm working on this now with different seats,G35 coupe and sedan foam/leather. I'll let you know they turn out.
| All times are GMT -4. The time now is 03:26 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
