Parking lights out! Help?!
Hey Guys hoping someone can help me out.
im in the process of doing painted headlights/ccfl conversion. My problem is all my parking lights are out, including the backlights on my ac/nav and such (also license plate and taillights(non brake)brake works fine so do headlights).. I still have cluster and ac lcd/status illumination. My map lights are also working so some of the functions on the bcm seem to be working. I checked all the fuses by the pedals and also in front of the battery but nothing was broken. I have an 04 coupe You guys got any ideas for me? any help would be greatly appreciated! |
there is another fuse box behind the battery and the parking light fuse is there. if i remember correctly i took the battery out to get good access to it.
^^LIFE SAVER!!! thank you!:bowrofl:
First 10 amp fuse on top was busted! |
your welcome please send check or money order to .............
j/k so now you see the light? |
HAHA! Wow, what a bad place to put a fuse block.
It was actually the new led blinkers I got causing the short!(vled - http://frickinbrite.com/catalog/prod...roducts_id=134) I tried it both ways (since leds have polarity) and it shorted both times so Im not sure whats up with those. They seem to make all the proper contact points in the harness. Thanks again for the help! This wouldnt be a proper deftronix post without a pic :P http://www.techelpdesk.com/g/bhousing2.jpg |
Did you have to remove the whole headlight to get that installed. One of my parking lights in the headlight assembly is out and I'm just trying to replace it with a normal bulb for right now.......unless anyone has a good color suggestion for a laser red coupe
