please help.
Old Nov 3, 2008 | 12:07 AM
Poptarts's Avatar
Swerving and Weaving
Exclamation please help.
ok so i just bout a wrecked g35 coupe. the body and all is great. the only prob is the running lights in the back dont work. the brake lights still work but no running lights. please help me
Old Nov 12, 2008 | 04:16 AM
Poptarts's Avatar
really 220 people looked and not one person knows how to fix.... so that totally sucks
Old Nov 12, 2008 | 08:40 AM
nameless's Avatar
err.. not like im a expert or anything... but ill try,
does the dash light and front dim light work? im quite sure its connected
Old Nov 12, 2008 | 06:30 PM
Poptarts's Avatar
no the little roll ball thing doesnt work.. i can roll it both ways and nothing happens. could that be the prob
Old Nov 13, 2008 | 07:50 AM
nameless's Avatar
im not getting you, roll ball thing?? whats that?? do you mean the light switch?, well if the low/high beam is coming on when you flick the switch then it might be the fuse.. the fusebox is located behind the battery..i fused one of the fuse before... you could start from checking there...
Old Nov 13, 2008 | 08:21 AM
GreenGoblin's Avatar
The goblin resurrection
I would start with the fuses... the roll back this is for the dash lights and in car illumination which the fuse is located in the drivers kick panel.... I am not sure about the DRL
Old Nov 13, 2008 | 08:50 AM
nameless's Avatar
Sorry i tried there last time and came out blank... mine was all written in japanese...i found the fuse behind the battery, in a black box, you need to slot the box up out to reveal the fusebox..
Photo of kickpanel fuse
this is the fuse cover beside the kickpanel... there is no illumination here...
Old Nov 16, 2008 | 05:52 PM
Poptarts's Avatar
ya i tried alll those.... i put a fuse tester to everything in my car and nothing. so idk what to do now.... and when i said rolly ball thingy. i ment my light dimmer next to the trunk opener.
Old Nov 16, 2008 | 06:05 PM
elayman's Avatar
if your city lights, rear lights, and clear corners don't work it's the fuse behind the battery.. first fuse in the upper left corner.. its a 15a i believe
Old Nov 16, 2008 | 07:24 PM
nameless's Avatar
err i dont have that in my car so i cant comment.. but my guess is light dimmer should be only for the internal dash light ...
you dont mind taking a pic of the roll ball and post it here...
just to reconfirm, you did check behind the battery right? its there...
Old Nov 16, 2008 | 09:43 PM
I think it would be the fuse box behind the battery also
Old Nov 17, 2008 | 01:56 AM
Poptarts's Avatar
ill take a pic right now.... and upload it be up in a few mins
Old Nov 17, 2008 | 02:08 AM
Poptarts's Avatar
picture for the rolly ball i was talking bout
<a href="http://s390.photobucket.com/albums/oo347/woodruff89/?action=view&current=2.jpg" target="_blank"><img src="http://i390.photobucket.com/albums/oo347/woodruff89/2.jpg" border="0" alt="rolly ball for lights"></a>
this is the light in the running light place and no lights????
<a href="http://s390.photobucket.com/albums/oo347/woodruff89/?action=view&current=3.jpg" target="_blank"><img src="http://i390.photobucket.com/albums/oo347/woodruff89/3.jpg" border="0" alt="Photobucket"></a>
Old Nov 19, 2008 | 05:50 AM
Poptarts's Avatar
bump still need help please.......
Old Nov 19, 2008 | 09:17 AM
nameless's Avatar
okay, please do let us know if youve actually checked behind the battery for the fuse... NOT the kickpanel...as elayman said... first fuse on the top ... 15A
2.. all the running is not lighting up? or just the tailights, does the dash light dim down, or the front nightlight light up? please do explain more specifically.. i wanna help but i need more clear awnsers...
