G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Lighting (https://g35driver.com/forums/lighting-177/)
-   -   2007 g35 Coupe LED's question... (https://g35driver.com/forums/lighting/363281-2007-g35-coupe-leds-question.html)
rockstar1292 Jan 9, 2011 05:37 PM
I used the search button but I'm just double checking...
I want to change the interior LED's but idk which ones I need and if all of them are the same. I want to make the dome lights bright white and the door and trunk lights a bright blue. Any other lights that I'm missing?
I was told that I need 194 WLED... but is this correct? I apologize for noob questions :cool:
Oh_Really Jan 9, 2011 11:55 PM
194 can be used for your trunk light. You need DE1375/DE3022 for your dome/door lights. Check VLEDS for some nice led lights. There is also someone in the marketplace selling the bulbs that you want.
rockstar1292 Jan 10, 2011 12:36 AM
Ahhh thank you! What type would I need for the license plate bulbs?
Thanks so much for the answer.
Oh_Really Jan 10, 2011 12:41 AM
http://www.sylvania.com/ConsumerProd...lacementGuide/
Go to that site, put in your car and you will get the answer you want.
superman331 Jan 10, 2011 08:11 AM
if you searched than there is a complete thread on this. It tells you the bulb for every light on our cars.
XiN Jan 10, 2011 01:06 PM
Just buy these.
https://g35driver.com/forums/accesso...plate-led.html
Probably one of the best interior LED's you can get. And Henry sells them in kits, so you'll get all the lights that you need to swap out.
rpataca Jan 28, 2011 07:19 PM
I just received my dome lights(map lights)(DE3175) and they do not fit in my car.... looking over these forums a few say that it should be 194?
I was excited to get my new leds in but now they don't fit... have an 07 g35 sedan.
Oh_Really Jan 28, 2011 07:55 PM
Are you sure they don't fit. They will fit unless whichever company you bought it from sent you the wrong bulbs. Take a pic. of them and post it up. The 194 will be used for your license plate or trunk light.
Also if they do fit but just aren't lighting up, try reversing the polarity by flipping them 180 degrees and putting it back in. If they don't fit in either your map or your dome lights, its possible that they sent you the wrong size.
rpataca Jan 28, 2011 09:11 PM
Not at home but I will post it.
I have the 194 and I used it for my tag and those work great. The bulbs I took out of the map light area look just like the 194. I will post a pic of the car and bulbs. Thanks for the quick reply!
rpataca Jan 29, 2011 10:03 AM
http://grab.by/8EJu
The bulb on the right is what I took out of the map light fixture. The bulb(3175) on the left is the one I purchased from V-Leds.com that sylvania.com and majority of the posts found on here say to do. Obviously the bulb doesn't fit. The packaging behind the bulbs is for the bulb on the left(3175).
What am I missing?
Oh_Really Jan 29, 2011 12:03 PM
Heh interesting. You said you have an 07 sedan right? I guess they changed some stuff with the remodel. Just get some 194 bulbs for your map I guess and try using the 3175 bulbs for your dome lights if you have a sedan so they aren't wasted.
But anyways, use blue for your dome, and white for your map lights. Trust me. If you get pulled over, you don't want the cops seeing your blue map lights as your trying to find your insurance/registration because you can't see anything.
rpataca Feb 2, 2011 02:44 PM
Yeah it's an 07 sedan. I guess they must have. Looking over some other posts I did find one post that mentioned all the bulbs are 194. I'm gonna send the other ones back and purchase the right ones.
Good call on the blue/white lights! I'm guessing your speaking from experience! haha.
Thanks for your help!
© 2026 MH Sub I, LLC dba Internet Brands
