G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Lighting (https://g35driver.com/forums/lighting-177/)
-   -   Glovebox light won't turn off!? (https://g35driver.com/forums/lighting/437660-glovebox-light-wont-turn-off.html)
PLENUMCOUPE Feb 16, 2014 12:25 PM
As the title states, it only turns off when the cars off but when it's on I can see through the little slit at the top (when the glove box is closed) that it's lit up in there and is always on. Anybody else have this problem?
Ogee Feb 16, 2014 07:58 PM
Even if your cars' engine is off, but if your headlights are on, the glove box light will stay on. Make sure your headlights are completely off first.
WhosUrBuddiee Feb 16, 2014 08:14 PM
Cover the light with some electrical tape. Problem solved.
lilindienplaya Feb 16, 2014 09:08 PM
there's no switch on the Gs the light stays on. There is a write up on how make the glove box close tighter so you cant see the light through the gap.
PLENUMCOUPE Feb 16, 2014 09:24 PM
Yeah I noticed its in sync with the headlights. So pressure switch isn't bad. Figured this was normal since it's always been like that. Thanks guys
WhosUrBuddiee Feb 16, 2014 09:26 PM
2 Attachment(s)
Found the TSP for your problem
Attachment 191675
Attachment 191676
PLENUMCOUPE Feb 16, 2014 09:37 PM
My glovebox isn't overly-open or loose. I just wanted to make sure whether it's normal or not for the light to be on when closed.
© 2026 MH Sub I, LLC dba Internet Brands
