Good headlight options?
So I've come into an issue with my current headlights on my 04 G35x Sedan. I got them all cleaned up and polished and followed a thread on here about cleaning them with sand paper and what not and I have severe scratching on my headlights and condensation on the inside of my headlights. I was told not to use a heat gun to get rid of the condensation because it could cause cracks once it cools down and would make the problem worse. So I guess I have come to a split road on what to do for new headlights. I don't have the money to spend on 06-07 Projectors and want to go with aftermarket ones. I just don't know what to be looking for because I don't want gaps or to deal with a conversions or un-necessary wiring. I found a couple of options I found on the forums just need opinions.
Well first of all you need to decide whether you need coupe or sedan lights lol.
If you got a sedan just get some used ones and clean them up.
For a coupe they cost a lot more used so your cheap option without DIY are China (Spec D, etc) headlights. If you're willing to DIY you can do a roughly 06 projector equivalent for around $300 but it takes longer than swapping an engine and is easier to mess up on lol.
Would these be my best options?
https://shop.redline360.com/products...YaAoOpEALw_wcB
http://www.autolightsbulbs.com/2004-...IaAhAaEALw_wcB
I also do have little cracks in the headlight due to where I live and the weather conditions. The lens itself is just bad.
Gman_Zman
11-12-2010 10:09 AM
