G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Media Share G35 Sedan V35 (https://g35driver.com/forums/media-share-g35-sedan-v35-308/)
-   -   Don E's G35 Sedan in progress (https://g35driver.com/forums/media-share-g35-sedan-v35/364840-don-es-g35-sedan-progress.html)
don e Jan 23, 2011 11:05 PM
I recently bought a 06 G35 sedan and new to this forum
Plans : Suspension and Wheels with fender work
Just wanna keep clean and simple
When i first got it.
http://i238.photobucket.com/albums/f...-37-04_741.jpg
Got the windows tinted and JDM clear corner lights.
http://i238.photobucket.com/albums/f...4715590804.jpg
http://i238.photobucket.com/albums/f...4715569797.jpg
http://i238.photobucket.com/albums/f...4715538106.jpg
Got the wheels Varrstoen 19x9.5 & 19x10.5
http://i238.photobucket.com/albums/f...on1ray/te3.jpg
Getting tires and suspension this week and some fender work.
The track car 93 Civic in progress also!
LSV 86x89 RS sleeved Nitrous
http://i238.photobucket.com/albums/f...90907-0923.jpg
http://i238.photobucket.com/albums/f...13-1141106.jpg
http://i238.photobucket.com/albums/f...214-211731.jpg
http://i238.photobucket.com/albums/f...00403-0909.jpg
http://i238.photobucket.com/albums/f...-02-49_489.jpg
http://i238.photobucket.com/albums/f...-35-19_623.jpg
http://i238.photobucket.com/albums/f...21-1955143.jpg
http://i238.photobucket.com/albums/f...20-0811138.jpg
CandlestickPark Jan 23, 2011 11:27 PM
Wheels will look good on your ride. Offsets of the wheels? What suspension are you going with? What fender work are you planning on doing, I would suggesting rolling them over cutting if you were planning to go that route.
TycoRC Jan 23, 2011 11:29 PM
prepare for some mad rubbing!
don e Jan 23, 2011 11:30 PM
offset is 12 F and 22 R , im getting megan coilovers.
don e Jan 23, 2011 11:31 PM
how bad are u rubbin on your setup?
CandlestickPark Jan 23, 2011 11:33 PM
Offsets are perfect. What tire sizes are you planning. You'll need to roll your fenders really flat front and rear. Do you have a camber kit in the rear, you'll likely need to dial in your camber out back.
How low do you plan to drop it?
don e Jan 23, 2011 11:37 PM
thinkin of gettin 225/35 or 235/35 F and 245/35 R yea fenders will be rolled flat , dont really wanna get camber kits but if i need to then i will. planning on goin low...
CandlestickPark Jan 23, 2011 11:57 PM
If you are going low then you won't "need" them, it will be just on less lever you can use for adjustment. For instance you may have to do a pull verus adding negative camber.
don e Jan 24, 2011 12:02 AM
i see.. im debating on front tire size 225/35 or 235/35...?
TycoRC Jan 24, 2011 12:02 AM
If you do Megan coilovers, I suggest street suspension. I have buddy club spec damper racing coilovers and they are a "True" set up like te Megan Racing Track setup and my back spacing between the wheel and coilover is about 2-3mm very close
don e Jan 24, 2011 12:05 AM
thanks for the info im gettin the megan street version.
r1forever80 Jan 24, 2011 12:09 AM
Looks good. Moving really fast. My offsets are the exact opposite and im running 225 on the 9.5 and 235 on the 10.5 and im at zero camber. needless to say i have pokeage. lol
don e Jan 24, 2011 12:16 AM
thanks any pics of ur car or front wheels?
r1forever80 Jan 24, 2011 12:29 AM
1 Attachment(s)
this is all i got
don e Jan 24, 2011 12:39 AM
what brand is your tires?
© 2026 MH Sub I, LLC dba Internet Brands
