G35x no heat blowing- resistor lication
where is the blower motor resistor licated on infiniti G35x sedan?
I think you mean RELAY and it's located on the back of the cabin fuse panel.
Relay location- disassembly
Originally Posted by cwalker852
(Post 7124831)
THANKS!!!! |
Cabin fuse panel, it's secured with two bolts and on the back are some blue relays. I'm not sure exactly which one it is for you but you can swap them. AutoZone carries the OEM Nissan relay.
