Lug Nut Torque Specs
Old 11-27-2009, 09:31 AM
garyfb's Avatar
Anyone know the torque specs for the lug nuts on an 04 G35X ?
Thanks
Old 11-27-2009, 09:32 AM
jimmyc13's Avatar
I think 80 ft-lbs, might want to see if others respond to confirm.
Old 11-27-2009, 10:49 AM
G35Papa's Avatar
You got it right jimmy, 80lbs. Drive for about 50 miles then re-check.
Old 11-27-2009, 11:01 AM
Mustang5L5's Avatar
80 ft-lbs
I go 3 steps...50, 65 and then 80. Then after 50 miles i retorque to 80
Old 11-27-2009, 11:19 AM
garyfb's Avatar
Great... thanks for the info.
Old 11-27-2009, 11:26 AM
azt108's Avatar
What is the significance? I'm assuming that it keeps the wheel perfectly centered?
Old 11-27-2009, 11:28 AM
5150DS's Avatar
If you overtorque you could damage the rim, rotor, or other parts of the suspension. Undertorque and the lug nuts could work their way off.
Old 11-27-2009, 11:29 AM
Mustang5L5's Avatar
Also helps prevent the brake rotor from heating up unevenly and potentially "warping" as well as the other reasons mentioned above. Lug nuts can snap too
If you are running spacers, you should def be torquing your wheels
Old 11-30-2009, 10:14 AM
Mr_pharmD's Avatar
wow, 80lbs? I was doing 95lbs for my coupe. Also anyone know if lite weight lug nuts are bad bc I feel these are soo lite that it may snap at hi speeds.
Old 12-01-2009, 07:45 AM
Mustang5L5's Avatar
Ultimately depends on who makes it and what material they chose.
But if you have to ask, then ask yourself is saving 2 ounces per wheel worth the risk?
Old 05-26-2019, 05:01 PM
1SickG35X's Avatar
I have a 05 G35x, AWD on some 19” aftermarket rims. Tinted windows. Automatic Transmission 😔
What about aftermarket lugnuts?
What if I have after market lug nuts? Do I still have to torque to 80 f lbs?
Old 05-26-2019, 05:07 PM
cleric670's Avatar
BANNED!!!
Received 2,456 Likes on 2,150 Posts
Coupe 6MT Premium RAS
If you have aluminum wheels you torque to 80 ft/lbs.
Picture Share
02-04-2018 12:41 PM
g.spot
05-09-2016 10:54 PM
VatoVazq
Steering & Suspension
12-23-2015 10:01 AM
prinny
11-22-2015 11:07 PM
NyCrAzY
10-01-2015 09:19 AM
Quick Reply: Lug Nut Torque Specs
