Marketplace Parts, Cars, and Misc items
FS: Polished Crawford Plenum!!!
Old May 2, 2010 | 12:42 PM
rcdash's Avatar
Talking Polished Crawford Plenum!!!
Polished Crawford Plenum with ceramic coating on the inside to prevent heat soak. Comes with all hardware though you may need to get some new nylon or high temp rubber washers for the center bolts (they warp as you tighten them, but cost only a few cents at Lowes - the ones I have on might work fine).
There is a 3/8" NPT plug in the neck of the plenum, which I used for my Haltech air intake temp sensor. You can take that plug out with an 8 mm hex socket if you need to use it. Otherwise, it has no additional taps (comes with 1 large and 2 small vacuum ports standard with nipple fittings, 1 not shown).
$325 + $10 shipping
Here is how it looked in my engine bay.
Old May 5, 2010 | 01:58 PM
rcdash's Avatar
Sold.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
