Place to Remove and Re-install Motor in L.A. County
I have contacted street image, and also SP Engineering. Are there any other shops somebody would recommend for this type of job, and there contact info if possible.
Also is there a shop around called Ballistic that deals with the G35 cars?? We simply need the motor pulled then re-installed after paint. No other mods done to it. Thanks!! |
Also is there a shop around called Ballistic that deals with the G35 cars?? We simply need the motor pulled then re-installed after paint. No other mods done to it. Thanks!! Rick |
^ Damn that's very nice of you...
It also sounds like a drug deal bout to go down. |
4myride.com
909.390.3777 Opened from 1230pm-8pm Tues-Friday / Sat 1230-6pm (Noticed your G35 gives prop's to Autolink. Ask Kitty from Autolink about Tony from 4myride.com, I'm sure she'll vouch for the shop.) |
4myride.com is great! They just finished an engine swap for me and the car is fantastic! Tony is very up front with you about what is going on with the car in any stage of the work and keeps you informed. If I needed it done again, there's no question were I would go. Thanks Tony.
Later, Ray |
i highly recommend SP Engineering
