Stock Immobilizer
Hey guys, I was just wondering about the stock immobilizer. If I'm sitting in the car and arm it through the key fob and manually unlock the door I can get the factory alarm to go off. As it's going off, I can still stick the key in and start the car. Is this right? Shouldn't the immobilizer kick in when the alarm is going off? Or is the chip in the key basically the immobilizer? Thanks.
as long as you are using a correctly chipped key, you car will start. i believe the immobilizer is only for anyone trying to hotwire the car or using a copied key that does not have a correspondingly programmed chip.
having some issues
Just trew 2 codes p1610 p1614 how can i fix this without taking to the dealership
That's not going to be cheap. Either take it to the dealership, or reflash it with Uprev to completely disable NATS (Nissan Anti Theft System).
stick immobilizer
How u do the uprev flash at n how much u think it will be ..can it be done ..
Its easy, and costs $350-500 depending on how you do it.
car wont turn over
Were can i get done asap..n j think thats the reason it dnt crank over
