Engine stalls. Need help!
When I am at a stoplight, or even sometimes making a slow turn, my engine will stall out! The dash lights stay on but I noticed the RPM's drop to zero and I have to turn the car off then on again. It is usually a long start too, almost to the point where it feels like it won't start but it eventually does. The service engine soon light also comes on, but goes away when I turn the car back on.
Thanks |
first thing i would do is pull the code when ur SES light comes on, thats your starting point,
Originally Posted by 1st-gen-G
(Post 7086688)
Thanks again for the quick reply! |
Also, do I just replace both sensors? Is it worth it?
bank 1 is passenger side and i went with oem when mine failed. i changed only the faulty one and its been over 2 years since with other one working properly so i wouldnt throw additional money at it if it aint broke
this site has already covered this issue check out the following thread https://g35driver.com/forums/engine-...-ses-slip.html |
Check out the thread I started a couple of days ago, 211 views so far and not one comment. This site really is dying a quick death I fear...........
https://g35driver.com/forums/g-spot/...xperiment.html |
Clean your throttle body and MAF.
You have carbon on the butterfly hinges of your tb. C'mon, guys, this is elementary. |
