Car randomly dies and doesn't start
Hey guys. Over the last month or so my car completely lost power. 2 times I was sitting at a traffic light and 1 time i was on the highway coasting at 10mph in traffic. Also, the car likes to act like it's dead and doesn't start randomly. The temperature was mixed when it happened. Hot and normal. Today I replaced my battery and alternator because my voltmeter was reading 17v not running and 19v running. After I replaced those 2 parts I realized my voltmeter was wrong. It's at the normal voltage.
Any insight would be greatly appreciated. Also there was 1 day I noticed the red security light was solid red
edit** 04 g35x
edit** 04 g35x
Received 2,456 Likes
on
Coupe 6MT Premium RAS
on
Battery to chassis, under the coolant reservoir to the timing cover. Those are the ones I'd focus first. I would also check the positive side connections, battery-fusible link, wire to the starter. Usually when the engine just stalls for no apparent reason it's because it lost power, if it starts to idle all wierd and stumbles before stalling that's a different story.
Your NATS light being solid red after a stall shouldn't signify anything important, NATS is only for the initial START of the engine but once everything is running it doesn't have to send a constant signal or anything.
on
Very important update
Today the car did something very strange. I was stuck in traffic and I went to hit the gas and nothing. Car was running and everything. I put it in neutral and hit the gas and it would rev up normally. Put it back in drive and nothing. So I got on the should, turned it off and it wouldn't turn back on.
PLEASE HELP!
PLEASE HELP!
on
laratta
14
05-20-2019 10:30 PM
khoacalacan
09-29-2011 08:28 AM
CleanWhiteG35
02-09-2011 10:01 PM
