G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Tuner & Dyno (https://g35driver.com/forums/tuner-dyno-287/)
-   -   Here's my dyno...need advice on tuning (https://g35driver.com/forums/tuner-dyno/181355-heres-my-dyno-need-advice-tuning.html)
cryhavok Oct 6, 2007 12:56 PM
Hey guys,
I have a 2003.5 G35 Coupe 6MT with the following mods:
Random Technologies High Flow cats
Borla True Dual catback exhaust
350z intake tube
JWT Popcharger intake
Here's a dyno I did a few years back...nothing has changed since then.
http://img.photobucket.com/albums/v1...k/f96ca40a.jpg
This was done with about 10 other 350Z's...my car was the 2nd highest HP car there, only losing to a heavily modded 350z. Most of the other Z's were in the 230-240 range (with one at 217 hp :eek: )
Unfortunately, I don't have a plot of the torque. My AFR seems pretty steady though...
Do you guys think it is worth it to get the car tuned? Any guesses on how much power is still untapped? I would be going with the UpREV/Osiris package and having it "e-tuned."
EvolutionGSR Oct 6, 2007 04:56 PM
Well, with my very limited knowledge, here is what I can tell you. I'm only advising with information I learned based on my recent dyno.
Looks like your AFR is steady but lean. Its probably from the HFC's and true dual. You may be able to get a tuner to bring that line closer to 13 and pull some power out of it across the band.
2slo2bfurious Oct 11, 2007 07:53 PM
I think your money would be better put on buying a new mod...
Jeff92se Oct 11, 2007 08:03 PM
Seems a tad lean in the lower rpm ranges. If that's all wot thoughout the dyno test, then a reflash should net you some hp at low/mid rpm ranges. A/F seems okay up top. You might be 1 mod away from running too lean though. ie.. plenum or plenum spacer mod
but I'm not an expert.
cryhavok Oct 11, 2007 11:41 PM
Thanks for the replies guys :biggthumpup:
The pulls were all done at WOT. 2 in 4th gear and 1 in 5th.
I think I'm going to go ahead and get the tune done. I would like some more midrange power...I don't really wind her out to redline all that often, so I hopefully would gain some more "useable" power. The guys at UPREV have also been very helpful in answering my questions.
Jeff92se Oct 12, 2007 01:05 AM
I agree. Although the Osiris is great in the fact that they can email you a reflash, he has the older gen G w/o the widebands.
So he can't just log a run on a Uprev Cipher and get a reflash. He'd have to install the plenum/spacer and get another dyno session done. So might as well get the mod first, get another dyno run and top it off with a reflash.
If he had a newer wideband 02 G (05+), he could reflash now. Add the mod, do a datalog and get another flash. Basicly eliminating the dyno session (and cost)
Originally Posted by filanj
I agree with Jeff. Get a plenum or plenum spacer, then go for the tune. It'll be a lot more cost effective and you'll get the extra kick in addition to the tune from the spacer or plenum.
cryhavok Oct 12, 2007 03:31 PM
Thanks for the responses.
I'll go ahead and get the 5/16 spacer. I assume motordyne is the one to get? I haven't been in the modding scene in about 3 years!
RebelinRI Oct 12, 2007 11:27 PM
You're just about done. Most VQ'a top out at 260whp range with bolt-ons.
cryhavok Oct 13, 2007 02:30 AM
filanj,
I remember back in the day when Kinetix first released their plenum, it was crap. IIRC it would warp and cause all sorts of problems. Has their reputation changed? I've searched, and really can't find anything about this V+ model.
What do you like about the V+ over the spacer? I'm not really interested in increasing the volume of my car anymore, just looking for what would be best in terms of power.
OffWithHisHead3 Oct 21, 2009 09:15 PM
My car produced 240whp prior to uprev tune...i have fast intentions intimidator exhaust with HFC, mrev 5/16th spacer, K&N typhoon short ram intake... after tune.. i was at 260whp.. Good gains for those amount of mods? what is average for those amount of mods? 260whp = about 319 bhp? eh... i have 07 coupe 6mt. dyno dynamics btw..
next is strupp headers.. i have em.. just have to install them... i heard around 20hp gain midrange??? True or false??
05G356MT Oct 21, 2009 09:38 PM
2 years...couldn't you have bumped a newer thread?
03threefiftyz Oct 21, 2009 11:26 PM
Fail................/thread
© 2026 MH Sub I, LLC dba Internet Brands
