replaced motor and haven't had the same power
Old Jun 11, 2011 | 01:30 PM
jwrape's Avatar
Ok, I haven't done another compression test but I did order a new Passenger side cam sensor to see if that helps with the lack of power. Should be on the front door step this afternoon.
Old Jun 12, 2011 | 09:44 PM
GrocryGettr's Avatar
Replacing the cam sensor is not going to help your lack of compression issue.
Old Jun 14, 2011 | 06:27 AM
jwrape's Avatar
I agree but I'm still not sure I did the compression test right.
I replaced the Passenger side yesterday and then drove the car. It felt the same but then gave me a Check Engine Light with a code of P0011. Driverside Cam Position Sensor, so I ordered that one and should have it in a day or 2.
We will see, what happens.
Old Jul 9, 2011 | 04:43 PM
slim17265's Avatar
when doing a compression test it is important to prop open the throttle body otherwise you will not get an accurate reading
Old Jul 12, 2011 | 06:10 AM
jwrape's Avatar
Could be my problem on that test
Hasanbaloch
Feb 29, 2024 08:45 PM
will091195
Jul 27, 2015 09:19 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
newg37
Jul 26, 2015 09:32 AM
papo020
Jul 17, 2015 10:30 PM
