New UpRev Osiris ARC Features - 2-Step, Flatfoot shifting, etc
#31
Follow up: Uprev ARC help
Dustin and Randy of uprev just replied, pointed out indicating my ARC is good to go. But what am I missing here concerning my toggle switch ain't responding to 2 step feature? Basically its just; VDC off, clutch in, and 1st gear. Then just floor it above 3k rpm witch should activate ARC? Correct?
Image by uprev personel.
#32
#33
Also make sure you are at a COMPLETE stop, I've had a couple instances where the car was rolling slightly (backwards even) and that tripped it. Doesn't work so good on hills..
If you can determine that's the issue ask Randy to raise the disengagement speed a couple MPH and you should be fine.
#34
Sorry if that's overly complicated, I troubleshoot electronics for a living, lol.
#36
#37
#38
Yes, ARC features are confirmed on your car. It's all user error at this point then.
seymore4 (09-13-2017)
#40
#41
A bad clutch pedal start switch?
As the issue continues; Is there such thing as a bad clutch pedal start switch?
So today, I took off the start switch, took it apart, cleaned it with CRC QD Electronic Cleaner, and adjust its position to be closer to its clutch pedal before securing it with its 14mm nut. ...still no luck getting that 2-step to kick in, still all "0" values on the ROM Editor logging. (See attach screen capture image.)
Is there any other switches or circuits between the clutch pedal and transmission that need to be check?
#42
Does your cruise control work at all?
There's 2 switches on the clutch pedal. The one at the bottom gets pressed when you push the pedal all the way down, that one is used for the starter interlock.
The second one is at the top of the pedal. It should be pressed at all times when the pedal is up. That one is the cruise control sensor, it disables cruise as soon as you touch the clutch pedal. Might need adjustment if your pedal isn't traveling all the way up. Should be about 1/8" gap, any more than that and it won't read correctly.
ArkansasG35COUPE (11-06-2020)
#43
#44
I did 4k arc launch the other day and broke my already ripped diff bushing lol! So freaking fun but too bad I won't get to do it again until I replace them bushings, I don't want to damage anymore of my drivetrain parts LOL!
I was thinking about it all day with a smile on my face!
#buildbreakfixrepeat
EPiK (10-31-2017)
#45
Received 2,456 Likes
on
Coupe 6MT Premium RAS
deeliciousqueen (09-20-2017)
