04 5at g35 dyno tune w/ full bolt ons, C8 cams
Old 12-17-2018, 12:18 AM
arock292's Avatar
I got my 5at 04 G35 tuned by Nikk at Soho Motorsports.
The dyno results
289whp
272lbft
Mod list:
JWT C8 CAMSHAFTS
PPE LONG TUBE HEADERS
XYZ PIPE
CIRCUIT WERKS DUAL EXHAUST
PORTED LOWER PLENUM RUNNERS
MREV2
SHIFT TECH PERFORMANCE UPPER PLENUM
NWP 75MM THROTTLE BODY
FUROOKIE 3.5" INTAKE
MD 1/2" PLENUM SPACER
OEM REV UP OIL PUMP
GTR 550CC INJECTORS
1PIECE ALUMINUM DRIVE SHAFT
The greenline is with the 1/2" spacer, ported lower plenum runners and shift Tech performance plenum. The red line is when I had a 5/16" ​plenum spacer and stock lower and upper plenum.​​​​​​
Here's a picture of the shift Tech performance plenum. (excuse my dirty engine bay)
The inside of the plenum it's completely polished and the support columns have been removed. The plenum neck being bored out to 75 mm all the way through.
Old 12-17-2018, 01:20 AM
Scorpi0's Avatar
For all that money and time spent, wouldnt it have been better to just go with a turbo kit?
Old 12-17-2018, 07:11 AM
arock292's Avatar
Yes, for more power it would have been more cost effective. All of these modifications have been done over the length of time that I've had the car not all at once. I bought it in 2008 and started modifying the car little by little. I had the cams put on because I had to get the timing chain and valve covers replaced. So might as well do the cams while they were in there. Plus I always wanted a cammed NA car. I might put on a single turbo kit, I know the c8's will help it make more power if I go that route.
Old 12-17-2018, 08:06 AM
Urbanengineer's Avatar
Received 1,016 Likes on 935 Posts
Plus you get all the benefits of NA power! No turbo spike life.
Old 12-17-2018, 08:36 AM
arock292's Avatar
Yep, being NA definitely gives me a little bit more peace of mind when I'm pushing the car really hard.
iceb0urne
Tuner & Dyno
11
08-22-2015 02:10 PM
trey.hutcheson
Tuner & Dyno
36
07-08-2007 11:50 PM
Garnet Canuck
06-14-2007 10:38 PM
Quick Reply: 04 5at g35 dyno tune w/ full bolt ons, C8 cams
