Using bluetooth for audio (2018 thread)
So I just got a 2008 G35X and it has the RCA inputs and then right above those it has an old 30-pin connector. I am making this post because I have searched through several pages on here and it seems like a lot of the products people are suggesting are outdated, or the information contradicts what other members are saying (for example, I saw someone suggest buying a 30-pin to lightning adapter for audio but then I saw several posts about the phone not even recognizing that is was plugged in and such).
Anyway, I understand that the easiest way for my to play audio via aux would be using an RCA-3.5mm then 3.5mm-lightning connector (then into my iphone 8 plus). However, what are the current bluetooth options? Again, everything I am seeing is several years old. I would prefer to play music from my iPhone 8 via bluetooth, that way I can also charge my phone. |
Originally Posted by jb_16
(Post 7146676)
I ran into the same thing you did - many links to accessories that are no longer available or are now mostly outdated.
If you want to stream audio via Bluetooth, which I am doing, I bought this. You only need the "car pack" version though it looks like they've changed their pricing. The car pack doesn't include all of the RCA cables (that you don't need for a car) and had a lower price but that's not the case anymore.... You also need a cigarette lighter power adapter with USB, RCA male to 3.5mm male, and I'd recommend getting a noise isolator. The adapter I linked to doesn't have one (the device itself is tiny, smaller than a USB flash drive) but the "noise" is only noticeable when there's silence but I still added one afterwards. Note: You can't control your device (in your case, your iPhone 8) through the car in any way. Otherwise, it works great and sounds great. |
Your local computer shop will have Bluetooth adapters for under $20. The one I selected has pause / play / vol up / vol down / previous track / next track , and sits in front of the armrest on top of the cup holder flap in the center console.
I'll go out at lunch and snap a picture of my setup.
Here is my power adapter and Bluetooth adapter. BT adapter has an on/off switch to save the battery, and is kept charged with the micro usb cable. Turning the adapter off will cause the ipod to stop playing. Turning it back on will cause the ipod to automatically connect,unless another bluetooth device is available.
https://cimg2.ibsrv.net/gimg/g35driv...55de6711c0.jpg Ipod in place, kept charge by USB. Turn the BT adapter on, wait for it to connect (about 3-4 seconds) and push play. https://cimg9.ibsrv.net/gimg/g35driv...a50e82f601.jpg Third cable is to charge my phone, 4th slot gets used to charge the wife's phone or a powerbank. |
Here's the BT adapter I use.https://cimg3.ibsrv.net/gimg/g35driv...ee071c230c.jpg
Originally Posted by Joenavy85
(Post 7163523)
Here is my power adapter and Bluetooth adapter. BT adapter has an on/off switch to save the battery....
Originally Posted by Hall Stevenson
(Post 7163544)
I'm positive there's no need to turn it on/off. That 5v socket in the console isn't powered when the car is off. My car is sitting outside the window at work and my iPhone isn't connected to the BT adapter I use.
Ahhh, I see. Didn't realize that yours has an internal battery. I have a Tunai Firefly BT adapter with no battery, so that's the difference. It turns on/off with the car. I also have an iPod Classic but my G35 has the optional built-in iPod connector. What iPod is that, by the way ?
Nano, 7th Generation. With a case I picked up from eBay
(Post 7163523)
Wow, I've been looking for a bluetooth solution. Thanks for posting.
If your car has AUX connections, definitely use those over an FM transmitter. You will hear a difference in sound quality.
