G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   V36 Brakes, Suspension, Wheels & Tires (https://g35driver.com/forums/v36-brakes-suspension-wheels-tires-374/)
-   -   For those with Akebono's (https://g35driver.com/forums/v36-brakes-suspension-wheels-tires/332774-those-akebonos.html)
soundmike Apr 9, 2010 02:08 PM
Have any of you guys, who've retrofitted the Akebono's on your G35/HR sedans, noticed slightly more forward bias?
The car seems to nosedive more with aggressive braking, something i've never had issue with on the stock "S" brakes.
I'm comparing OEM set-ups on both counts (rotors, calipers, pads and all). The only non-OEM part in the whole equation are the 2pc rotors up front and SS lines on the Akebono's.
It's not that big of an issue, as i can always replace the rear pads with slightly more aggressive one's, but in case something's amiss i want to nail it down.
Thanks.
- Mike
E-Ticket Ride Apr 9, 2010 02:47 PM
Are the front pads oem too?
soundmike Apr 9, 2010 03:10 PM
Yep, F+R for both the Akebono's and the prior "S" brakes.
Jeff92se Apr 9, 2010 03:17 PM
The difference might lie in how the HR equipped master cylinders are distributing brake power front/rear vs how the VQ equipped units are doing it.
soundmike Apr 9, 2010 03:38 PM
I'm not sure i get that... isn't an HR motor still a VQ? Mind clarifying?
From what i've read prior to going this route was that the MC for HR sedan's and coupe's are the same. Then again, you may be right about the tweaks they made between applications. Or perhaps they put less aggressive pads on the rears? (relatively anyway, these are just plain 'ole OEM pads after all).
Jeff92se Apr 9, 2010 03:43 PM
I don't know if the master cylinders are exactly teh same as far as their bias. You could try to put more agressive pads in the rears. That can affect bias a bit. Might help you get back to a more even brake feel.
E-Ticket Ride Apr 9, 2010 03:43 PM
Assuming everything's the same, maybe it's just the additional bite of the RB rotors.
Cabad85 Apr 9, 2010 06:50 PM
op, i actually will be installing mine tomorrow, but in regards to your question. I have read the FSM for our car and compared the diameter of the brake master cylinder and booster to the G37 coupe with akebono's. There is a couple of mm difference between the two. That may be the issue; as for the exact measurements. I will have to get back to you on that, lol.
Q8y_drifter Apr 10, 2010 06:07 PM
probably the RB front rotors. I don't know about the MC. Why would they change the MC on the coupe anyway? what about the non-sport coupe? does it have the same MC as the sedan or the Sport coupe?
© 2026 MH Sub I, LLC dba Internet Brands
