Concave wheel Offset? XS dropped on Eibach's.. Need Help
I need some help picking the best offsets for my XS Sedan, im dropped on eibach pro kit & have upgraded to akebonos. The design team recommends I run:
Front 20x9 +40 Rear 20x10.5 +45 Those specs dont sound right to me, I dont think they have taken into account my brake upgrade & the drop. I was thinking more along the lines of. Front 20x9 +32 Rear 20x10.5 +32 or Front 20x9 +35 Rear 20x10.5 +37 I want them to sit flush with the fenders not tucked in, im not really into the poke or stretched look. Forgot to mention tires I will be running: 245/35 & 275/30 Any help would be great. |
VOSSEN isn't it?))))
If you want the rims to sit flush with the fender then go with 20x9 +25, 20x10.5 +32 with the tire sizes you gave. Take a look at the marketplace there is a company called vertini and they have came out with new concave wheels which will look good on the sedan
Originally Posted by BloNdine
(Post 5710250)
Originally Posted by sunny G-35 NYC
(Post 5710263)
Will those specs work with Akebonos? Could I get away with a 20x9.5 in the front? |
I thought on the X's you could not run a staggered set. All the wheels dia and offset need to be the same or you mess up the AWD system??? NOOB on wheels sorry.
Originally Posted by ANMVQ
(Post 5710322)
(Post 5710322)
Originally Posted by Chi_g35
(Post 5710427)
Offsets wont change the rolling diameter of the wheels. The diameter needs to be as close as possible.
Ah ok thanx- So as long as the rims are all the same( 20 inch) he is ok? |
Originally Posted by lundy
(Post 5710431)
Nope, you can stagger an X no problem. Just make sure tire sizes are the same overall diameter. However to the OP 245/35R20 and 285/30R20 tires should be used.
(Post 5710451)
http://www.discounttiredirect.com/di...foTireMath.jsp 245/35 and 275/30 are .25" off where the 285's are only .02 so the 285's seem like the safer choice. |
(Post 5710575)
As long as the overall diameter of the tires is the same. Calculate with this:
http://www.discounttiredirect.com/di...foTireMath.jsp 245/35 and 275/30 are .25" off where the 285's are only .02 so the 285's seem like the safer choice. Im more concerned with the correct offset to sit flush. Are these the best offsets for my car? 20x9 +25, 20x10.5 +32 I know R34 Eclipse on the myg37 forum picked up a set of shallow concave DPE's with these offsets. But it was for a coupe. |
Right now I'm on eibach springs and im running 20x9 +20 all around and I don't have a problem with rubbing. since you are going with 275/30 you should be fine with running 20x10.5 +32 in the rear. What wheels are you looking to get
(Post 5710666)
I recieved a sponsorship from Rennen Modular and will be posting specs on my full build very soon. |
as long as you got enough negative camber the +32 should be good. Let me know how the 275's work out. I decided not to run them in fear of damaging the AWD system with the different diameters.
| All times are GMT -4. The time now is 05:54 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
