G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   V36 Brakes, Suspension, Wheels & Tires (https://g35driver.com/forums/v36-brakes-suspension-wheels-tires-374/)
-   -   After a couple days on H&R's (https://g35driver.com/forums/v36-brakes-suspension-wheels-tires/372077-after-couple-days-h-rs.html)
lundy Mar 30, 2011 01:25 PM
I'm done with them. I don't know how some of you are able to handle the ride. It definitely clear they are not rated for the heavier 2nd gen (which I was told) but I didn't think it would be this bad. It did make me order some BC's though so it's not all bad. If the Tire Rack doesn't take back the H&R's I'll be selling soon.
J2S2M Mar 30, 2011 01:36 PM
Wow really?! I've been on my H&R's for over 2 years now and 0 complaint thus far. Only thing is that I feel the wear and tear on my OEM struts over time. Not enough dampening left in them, so I am going to pick up the Tokico HP blue struts soon.
Did you get an alignment after the drop? If I were you, I'd give it another week to let the springs settle fully, then get a final alignment before you make your decision.
Just my .02
lundy Mar 30, 2011 01:47 PM
I do have an X though. Maybe the extra weight in the front was causing my issues. It would bottom out hard on medium size bumps. My struts/shocks are almost new too. OEM though only because Tokico doesn't make any that will bolt on to the X. I don't think the alignment would keep me from frequently bottoming out. Oh well, I had a bunch of money in my paypal account I was looking to use anyways lol
Hossmaxima Mar 30, 2011 01:48 PM
The H&R's are suppose to be one of the best quality springs out there.
J2S2M Mar 30, 2011 02:24 PM
The extra weight in X vs. RWD is pretty insignificant. Maybe the difference of having just one extra passenger in the car. I think your problem with bottoming out is due to the fact that the H&R springs offer an aggressive drop especially in the front compared to Eibach, Tanabe, etc. I believe it offers the lowest drop for our 2nd gen sedans without going with coilovers. Once you drop your car, you have to get used to driving with the lower stance. Take bumps cautiously and angle your car for extra clearance. Maybe you are new to driving low? Anyway, I would give it some time before you dump the springs after just couple of days of use. Btw if you have excess bunch of monie$ in your paypal account, I can help you dispose of that stuff. Feel free to send it my way, jasonm220@hotmail.com :p I can help!
platinumg35x Mar 30, 2011 02:28 PM
you'll be happy with the bc's!
nghiars Mar 30, 2011 02:39 PM
Letting the Springs settle and getting an alignment (w camber/toe kits if necessary) should help. Your caster is probably off so the strut may not be working at the right angle making it less effective.. It's definitely cheaper to try and will save you life on your tires as well.
Then again.. if you can afford to go with coils, Do it!!!
lundy Mar 30, 2011 04:03 PM
I've had lowered cars as far as I can remember. Anything from the cheap coilover sleeves on my Civic/Integra when I was a little one to Tein SS's on my last car. So that's not the issue. I feel like something def isn't right. It shouldn't bottom out this easy. And when I say "bottom out" I mean the strut fully compressing to the point of no more travel. The bump I speak of aren't aggressive ones. Something you'd see on the 55 or the 91... More so just humps. Something as small as that causing the suspension to fully compress just doesn't feel right. I don't know... Coils are already ordered though.
It just seems like there is next to no travel in the suspension anymore. I understand lowering on a factory strut takes away from that but it's never been this bad. It feels like the springs are too soft mixed with the soft OEM struts are my issue. Coils already ordered. SPC camber kit/toe bolt came with em.
sunny G-35 NYC Mar 30, 2011 06:15 PM
maybe you blew a strut. Check it out because I know that it is possible to blow a strut and it will fukc up the ride quality. If not how much you wanna sell the H&R's for PM me
lundy Mar 30, 2011 06:27 PM
Struts and shocks are almost new. I really don't know what it is. PM Sent
vp-g Mar 30, 2011 09:08 PM
I have H&R coilsovers and they ride very nice..
lundy Mar 30, 2011 10:19 PM
They are nice. Not made for the X though :mad: I'm sure I'll like the BC's.
808MIKE Mar 31, 2011 03:49 AM
Sure WHoever Installed the Spring Installed the Front Correctly? And did not put it upside down, meaning the Soft side of spring rate is on top, and the Stiffer side on Bottom? Makes me wonder if u bottom out that easy? Should double check Struts and springs make sure they are Correctly Installed?....
Defratos Mar 31, 2011 05:08 AM
My car bottoms out on my JIC coilovers :(
But that's after 2 years of use, so I think one of the struts are gone.
CreativeDesignZ Mar 31, 2011 09:44 AM
your springs were put on incorrectly and possible might not be seated on the perch or you blew your shocks, new or not sometimes freak things happen. HR's are one of the best
© 2026 MH Sub I, LLC dba Internet Brands
