Akebono with Stock Brake Lines
Old Aug 1, 2013 | 01:48 PM
OMG35S's Avatar
Question Akebono with Stock Brake Lines
There are different answers to this question and I'd appreciate if someone knows exactly what I need to make the stock OEM lines work with my Akebono Set-Up.
From what I understand the Akebono BBK uses a different banjo bolt than the non-sports? So I need to find and order 4 of these banjo bolts?
What do I need in order to use my OEM lines with the akebono?
Thanks!
Old Aug 1, 2013 | 02:19 PM
OMG35S's Avatar
http://www.the370z.com/brakes-suspen...rt-pics-3.html
I came across this thread and post but it doesn't say anything about any bolts? Does the hard-line bolt up straight to the caliper without any banjo bolts? There's only a mounting bracket for the rears and not fronts? Is there somewhere to mount this bracket if my car isn't factory equipped with the Akebono?...
If I purchase these OEM lines, what exactly bolts up to the caliper?
1. 46246-JK60B left front caliper hard line
1. 46245-JK60B right front caliper hard line
1. 46315-JL00A right rear caliper hard line
1. 46316-JL00A left rear caliper hard line
1. 55286-1MA0A right rear hard brake line caliper mounting bracket
1. 55287-1MA0A left rear hard brake line caliper mounting bracket
4. 01121-04761 bolt for mounting rear caliper bracket
There's no straight-forward thread that explains the process of upgrading to BBK. Just a lot of mixed information here and there. After the install I'll post up a thread explaining exactly what you need.
Let me know so I can finally install this BBK!
Thanks
Old Aug 3, 2013 | 12:13 AM
E-Ticket Ride's Avatar
Why not SS lines? I'd guesstimate that 90% of the difference in "feel" is due to SS lines.
Old Aug 6, 2013 | 10:01 PM
txg35x's Avatar
I used the stock hard lines that you stated. The hard lines bolt right to the calipers with no banjo needed.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
mushu
Jul 15, 2015 03:55 PM
