Front suspension noise, G35X
Hello everyone, new to the forum, just picked up a high miles 2005 G35X with a suspension issue. I replaced the upper control arm, as the ball joint was bad, but there is another noise that I am having trouble pin pointing. Not matter what speed I am going, when I even tap the brakes, there is a clunk from the from right suspension. Even under idle power and a slight tap of the brakes, there is a clunk. Viewing it from the outside of the vehicle I can see the odd hesitation of the wheel when the noise occurs. There is no obvoius where in the other bushings or ball joints, and being that it happens at a crawl, I cant imagine it being a bushing as the suspension really isnt loading at that speed. I am now considering front axle, and suggestions?
My Jeep used to do this, ended up being the front upper control arm bushings. The size of the hole was slightly oversized, so it had clearence without any wear. I bought a set of Moog bushings, installed them and it hasn't made the noise since. Also, you might be able to post this in the V35 tech section for a second opinion.
irfanprasla
03-16-2012 11:34 AM
6MTsdn03
12-04-2005 11:05 AM
6MTsdn03
02-13-2005 10:49 PM
