Help Finding Front Sway Bar Links for 08 G35x??
I have been reading that Powergrid is the best for sway bar links. Went to their ebay page today to ask some questions and the rep told me they only make rear sway bar links for the AWD. If I was to purchase the Powergrids for the rear, any recommendations for front sway bar links? SPL I've been reading are bad.
These Whitelines look sturdy but people have been complaining that they unscrew...https://www.autoanything.com/suspens...A6664A0A0.aspx. Seems like sway bar links are a problematic decision.
I plan on purchasing a set of front and rear Hotchkis sway bars for the vehicle. Recommendations on what to do about the front?
Received 2,456 Likes
on
Coupe 6MT Premium RAS
I just put a Moog link on the front driver side of my 06x. It's the same Moog part number. It came apart the first time I jacked the car up. I don't know if anybody else does this but I've raised the car from the rear pinch weld jack point high enough to remove both front and rear wheels at the same time. I do this all the time like winter wheel changeover. But when I did this after putting on the new end link, the ball joint popped apart. Not sure if it would have popped apart if I had jacked up from the front jack point. Never had a problem with what I suspect was probably the original oem link on the car. I bought a mevotech to replace it but haven't put it on yet.
on
https://www.rockauto.com/en/catalog/...+bar+link,7580
i have used moog On Hotchkis sway bars in 08 G35x and my current 07 G35X. They get the job done.
on
on
I have SPL front and rear endlinks paired with my Eibach sways. They've been great. I run SPL products when I can. What are the negatives you've hear about the endlinks?
I have read from multiple threads that its recommended for sturdier endlinks with aftermarket sways, so any reputable brand will work, Whiteline being a good cost effective and quality piece.
on
on
Gary
superman22x
Steering & Suspension
09-24-2018 06:23 PM
g35man04
10-16-2010 06:30 PM
