Cobb tuning is ready!!!!!
Please Note: This part will only work with North American Infiniti G35. Also be aware that this device is currently not compatible with G35 Sedans with build dates from 2003 through May 2004. The ECU Part Numbers for these vehicles are as follows: - AM600 - AM601 - AM601 - AM602 - AM603 - AM604
Does this mean I can't get an AccessPort???? :S
Defratos, I'm assuming you'll be the GCC spec guinea pig
Cobbs maps are based off dyno tuning (unlike the Bulldog). Unless you have the exact configuration of the map description, the map may be off quite a bit. Even if you do have the exact mods mentioned, their maps are very conservative. If you look at the WRX, there are multiple "e-tuners" including cobb themselves who will fine tune their map based off logs (similar to what UpRev is doing). These guys usually charge $150-175 for the service, and while not comparable to dyno tuning, is usually much better than the off-the-shelf map.
Thats my problem, I need to give them my ECU number for them to check if it'll work, but I have no idea where to find it, does anyone know where I can find it on the car?
you half tocall the Infiniti dealer and give them your VIN number, and they can give it to you. My Local dealer said they could not give out that info over the phone, and I had to go down there! Which I think was complete BS and a waste of my gas!! Or call or PM Rick from Riverside. He gives out the info either way. Just make sure you got your cars VIN number ready!
What eaxctly do you mean on my 3?
#30
