Airbags indicator blinking with 08 G35 1800mi
Hi! All, My Airbag indicator warning light was came up today.Any sugestion or recommend would be appreciate.
right now i have unplug the battery.see if anything going on if leave it overnite. |
Got it fix.by a friend at G35driver.Thx!!! now i know how!!
Well it would help if you let us know how you fixed it?!
Here is the way how to fix the Airbag Warning Light. for all G35ers
Pls.follow these step. Turn the key to the on position and watch the airbag light. It should stay solid for 5-7 secs, and then turn off, and then start to flash. To reset the light, you must turn the key to on, watch the airbag light stay solid for 5-7 secs and as soon as the airbag light turns off, turn the key to the off position (you have to turn the key to off before the airbag light starts to flash, or you must start over). You need to repeat this 5 times. Try to start the car, and hopefully the light will be reset It's work great with my 08 G35X |
Thanks, just used this method and it worked!
