V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Fog Light Wire Harness
Old May 5, 2010 | 03:27 PM
alltechneeds's Avatar
I have a 2007 g35 sport sedan, I currently installed some custom HID fog lights on my ride, seems like the ballastic kept on burning out, so I had them removed, and put the OEM etc. Seems like the guys did not do a good job repatching the cables back, somehow some moisture got in them from the rain and burn out the bulb and melted part of the harness. Do they sell the harness alone and is it plug n play, where can I buy these online?
Old May 6, 2010 | 08:15 AM
5u30five's Avatar
check ebay. i saw some aftermarket fog light harness designed to work with higher watt bulbs. you can easily cut the burned out part and reattached it with the new harness. good luck.
Old May 6, 2010 | 08:22 AM
dofu's Avatar
20 Year Member
http://www.theretrofitsource.com/index.php
There are plenty of other sources if you take your time to google it.
Old May 8, 2010 | 07:52 PM
blkdragn's Avatar
More than likely the OEM bulb harness is available for sale just like that. I looked on the site above and found this:
http://www.theretrofitsource.com/pro...products_id=80
You might be able to replace the connector with the one that comes in this kit. Im sure you can find a 9006 connector somewhere else for cheaper.
deschutes606
Jul 18, 2018 09:34 PM
Freddy07g35
Sep 17, 2015 08:53 PM
whattf
Sep 1, 2015 07:42 PM
attarday
Jul 15, 2015 04:03 PM
