G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   V36 Interior, Exterior & Lighting (https://g35driver.com/forums/v36-interior-exterior-lighting-376/)
-   -   LED License Plate Bulbs Don't Turn On (https://g35driver.com/forums/v36-interior-exterior-lighting/407557-led-license-plate-bulbs-dont-turn.html)
bsw845 May 16, 2012 01:02 AM
Swapped my license plate light bulbs out for some white 5k LED bulbs from v-led. Turned on my lights and the led bulbs won't turn on. All other lights come on just fine.
Based on my research, I needed the 194 bulb. Didn't have time to switch back to my OEM bulbs to see if those still work (I.e. blown fuse) but I will tomorrow. These should be plug and play, right?
Bought these...
http://www.v-leds.com/5K-WHITE-HIGH-POWER-LICENSE-p7114849-1-2.html
Swagger_Jacker May 16, 2012 01:43 AM
You probably put them in backwards. They do only go in one way. Hopefully there is no damage done to them, remove and rotate that should work. I have those same bulbs in my car, no issues. just leave your lights on and try one way if no light flip and try again. Since u left them in and probably drove with your lights on depending on how long they may have burned up. hopefully not. G/L let us know if it works.
hurleyguys May 16, 2012 02:38 AM
+1 on backwards
bsw845 May 16, 2012 09:55 AM
You guys hit it on the money. Switched em around this morning and they work now. Didn't know they have to be put in a certain way. Thanks!
botlfed98 Apr 22, 2013 05:47 PM
link doesn't work, which ones work best for license plate bulb replacements: http://www.vleds.com/bulb-type/minia.../white-5k.html
msking May 9, 2013 04:09 PM
I bought these LEDs from www.lexenauto.com . Check them out. They were super cheap too!
ohfive May 9, 2013 04:17 PM
Great prices ..... any pics on your car?
© 2026 MH Sub I, LLC dba Internet Brands
