Memory seat button 1 and 2 illumination lights not
My #1 memory seat button illumination stopped working. The #2 button lights up fine.
The memory function works 100% on both 1 and 2.
How do I change the lights on #1 button? The INL service doesn't seem to cover that part.
Edit 1: It seems I need to replace the whole thing https://www.aaexport1.com/product/20...-control-9918/
Received 2,456 Likes
on
Coupe 6MT Premium RAS
Yeah it's all an integrated unit, mine went out shortly after I bought my car.
I completely forgot the seat had a memory function until you made this thread, I think I used it one time when a back passenger hit the button inside the seat release and moved my seat forward (didn't even know that function existed until it happened).
Is this the switch you need? When mine failed I accidentally bought the wrong one the first time and I had LITERALLY just thrown this thing in the trash 5 minutes before I saw this post. If this switch is the one you need I'll just mail it to you, otherwise it's going back into the trash can.
Check the harness connection, that's what was different on mine, I have a V35 coupe and I think this switch was from a V36. I don't know if someone cut the harness or if it was missing a part of the switch but there appear to be two extra wires in a short secondary harness that are cut off??? Either way wouldn't affect the switch function since it's separate from the harness.
pmoradi2002
06-12-2012 01:34 PM
DigMy35x
10-30-2008 01:03 PM
st4rk
12-27-2005 06:43 PM
