G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   What needs to be replaced with 20's (https://g35driver.com/forums/wheels-tires/10882-what-needs-replaced-20s.html)
Hooby Oct 5, 2003 09:36 PM
Do i need to replace my shocks/struts?
Will 20's fit with no rubbing?
What is the optimal tire size?
englishguy Oct 5, 2003 10:43 PM
Re: What needs to be replaced with 20's
20's fit and actually still leave a gap. i got 245 35 20 all around but you can go 255 all around or 275 in the back but i like to have the same tire size on the front and back so you can rotate them.
RaySur350GT Oct 7, 2003 10:49 PM
Nothing, just get an alignment after the install.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
gdupg35 Oct 8, 2003 01:51 AM
One thing you may need to replace is the empy space in your bank account after the purchase.
My sedan rubs a bit with the eibachs, even thought they tuck nicely in the wheelwells. Just make sure the offset is correct before getting them and you shouldn't have that problem.
Hooby Oct 12, 2003 09:11 PM
I think I'm going to go with Benedetto Dumanis
The tire package from www.superbuytires.com comes with
245/35ZR20
245/40ZR20
255/35ZR20
Which one should I go with?
Also, I think I'm going to go with Pirelli
PZero System Asimmetrico for tires. Anyone heard anything negative about them?
Here's a pic of them on a black g35
http://images.cardomain.com/member_i...703_2_full.jpg
gdupg35 Oct 13, 2003 04:43 AM
Do you have a sedan? 245/35/20 is the way to go if so.
g35mt Oct 13, 2003 11:07 PM
just curious, i thought the only time you do alignment is when you change the height of the ball. if you didn't lower your car, you shouldn't need to do alignment. I as told that way. Am i wrong to assume that? thanks.
g35mt
gdupg35 Oct 14, 2003 05:44 AM
As far as I know, you are absolutely right. There is no need for an alignment just from changing the tires and wheels, but I guess it couldn't hurt.
bacika May 28, 2004 05:27 PM
Did you get the dumanis? I'm looking to get the same ones, send me a picture if you can.
Hooby May 28, 2004 07:18 PM
I'm in the process of getting some used ones right now
lorinserbenz May 29, 2004 02:39 PM
Anytime you change wheels and tires you need to have your car aligned. When you change to a wider or different height tire your car sits differently than it did from the factory. If you dont get it aligned your tires will wear unevenly.
© 2026 MH Sub I, LLC dba Internet Brands
