G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   Widest Tires on Coupe 19's (https://g35driver.com/forums/wheels-tires/112045-widest-tires-coupe-19s.html)
RocketG35 Aug 14, 2006 05:40 AM
I posted this in the Wheel & Tire section and didn't get a response...so maybe someone can help me here.
What is the widest front/rear combo anyone has run on the Coupe 19's on the Sedan without any major rubbing? Rolling the fenders would be okay to me...let me know please!
ttrank Aug 14, 2006 01:50 PM
List the width and offset of the wheel and we will figure it out.
Klubbheads Aug 14, 2006 02:34 PM
33 rear offset for the stock 19s
OtisG35 Aug 14, 2006 03:52 PM
A friend of mine put 255 on his rears and I think that was the best he could do. He had a coupe though.
255 on stock 19s mounted on a sedan would probably rub though.
sjc1789 Aug 14, 2006 03:58 PM
i have the oem 19's on my coupe.. i put 255's on mine and it looks great... i only went one size up cause i didnt want the mushroom effect... the 255 are perfect
ttrank Aug 14, 2006 04:38 PM
255's on +33 but what width? I bet they would fit up to a 9" wide, anything wider at that offset will rub for sure.
chobble19 Aug 14, 2006 05:33 PM
i was hoping to fit 255-275/35/19 on my rear coupe wheels...:confused:
RocketG35 Aug 17, 2006 03:22 PM
So you had no problems with the 255 on the rear? Did you run a 35 series tire? What about the front tire...did you go 245/35?
RocketG35 Aug 18, 2006 05:41 PM
N/M realized you're talking about the coupe. I need info for the sedan.
© 2026 MH Sub I, LLC dba Internet Brands
