G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   Rims Tires I'm so confused!!! (https://g35driver.com/forums/wheels-tires/135309-rims-tires-im-so-confused.html)
Greenski2002 Jan 18, 2007 06:56 PM
OK I am ready to get my rims and tires for the summer. I am going with a 19 X 8.5 that much I am sure of. My problem is I just talked to someone at 1010tires.com and they said that a +38 offset will fit under the wheel. I have the G35 sedan wheel fitment chart by THX723 that shows that a +38 would probley rub in the front. Which is correct???
2. the guy form 1010tires.com said that I want to go with a 245/35/19. I though I would need a 245/40/19 to stay the same size as the stock tire and rim size. I need input. I live in Utah so I don't plan to put them on till spring but want to get them soon.
thanks
SFG356MT Jan 18, 2007 07:07 PM
Is your sedan lowered?
You should be fine with the 19x8.5 with +38 offset.
As for 245/35/19 vs 245/40/19, what the guy from 1010 is saying if you want the your speedometer to be true to speed the 245/35 is closer to your stock wheel and tire ratio. I believe by going 245/40 your speedometer will be slower than your actual speed.
© 2026 MH Sub I, LLC dba Internet Brands
