tread life of rear toyo T1r's
Hey guys, I have about 8,000 miles on my toyos and it's time for new rear tires. Is this about right??? My right rear is bald and the left has little tread remaining. I do drive my G hard around corners and through canyon runs but thats about it....Thanks in advace, Markiev
i see that youre on tein basics. how low did you drop it? if everything you have is in your sig, then i assume you didnt get a camber kit? what is your cambe/toe at? did you ever flip the tires?
Yes I do have a rear camber kit. not sure what my camber/toe is at. I'm dropped pretty low in the rear(about 1" clearance between tire and fender)
are you running an aggressive camber? is it the entire tire that bald or mostly the insides?
Pretty much the entire tire(right rear) is bald. The left rear still has tread and both fronts are fine. Sounds like I need to have my camber looked at before I put on a new set of rears.
my 275/35 lasted me about 20K.....basically stock, but I redline it almost everyday
| All times are GMT -4. The time now is 08:52 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
