Just ordered some 20's, need some info.
Old Mar 13, 2007 | 09:08 PM
fhumphrey04's Avatar
Well I just ordered some 20 inch wheels from a member on here and they have a +32 offset on the front and a +35 on the rear and I know they are not the most aggressive but I wanted them to look really bad-a__. Im in no way a wheel expert, more so completely clueless.
What can I do to make them flush with the fenders? I think that is what offset refers to, lol. Would spacers do this or am I completely wrong with my thinking?
rims are 20X8.5 front w/ 245/35/r20 and the rear is 265/35/r20 with a 9.5 wide wheel.
help!
Old Mar 13, 2007 | 10:16 PM
Chico's Avatar
if this is for the coupe...you can use 15mm spacers front and rear. Also change your tires in the rear to 275/30/20. they will be flushed with the fenders and no need to roll them.
Old Mar 13, 2007 | 10:25 PM
BadBoy06's Avatar
use the search..check out the pics to get a better idea
Old Mar 13, 2007 | 10:35 PM
G35Blake's Avatar
I suppose you just bought the Sterns from that guy in Austin?
If so, I almost bought those same wheels from the guy that was selling them before in Houston. I have a coupe and we test fit them and they fit pretty well and they really only need probably a 10mm spacer a 15 might not be to bad. They did look nice on the coupe.
Old Mar 14, 2007 | 03:59 AM
roblo's Avatar
Next time your shelling out big dollars on something get INFO first then order.
Old Mar 14, 2007 | 07:52 AM
Espresso's Avatar
Makes more sense to ask before buying. Hopefully he gets the right results without spending too much.
Old Mar 14, 2007 | 02:13 PM
I searched and new that they fit because another couple guys had that setup on their coupes. I also wanted to jump on them fast because they were a very nice wheel and in a price range I could afford.
Thanks for the info you guys, I guess Ill go ahead and order some 15mm spacers when I get some extra cash. And yes I did order the stern wheels, glad to hear they fit well
I couldnt really find any pics of them on coupes though, and yes roblo I did use the search Im so excited! wooohoo new wheels
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
dcsbh1
Oct 1, 2015 03:15 PM
