G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   Tire size for OEM 18's (https://g35driver.com/forums/wheels-tires/149414-tire-size-oem-18s.html)
ron4row2 Apr 5, 2007 12:04 PM
I just purchased some OEM 18' coupe wheels for my 04 Sedan. What is the largest tire I can place on them. From what I have read I can go 245/45/18. Tire rack suggests 225/45/18 front, and 255/40/18 rear. I want to stay the same size all around so I can rotate the tires. Will 255/40/18 fit all around or should I go with the 245/45/18?
nghiars Apr 5, 2007 12:19 PM
are you lowered, if so on wat because 255/40 might rub.. i dont think there would be any issues if you ran 245/45/18 all around
ron4row2 Apr 5, 2007 02:58 PM
I'm not lowered. My concern is the width of the tire on the front rim. Will it fit? I know it isn't as wide. Also, will it rub anywhere.
Thanks
Gdup35sedan Apr 5, 2007 02:59 PM
All the wheels on the oem coupe 18's are the same size. 18x8 +30
If you dont plan on lowering the car then a 245/45/18 will fit all around on the sedan.
-GP-
ron4row2 Apr 5, 2007 09:15 PM
Is there really any advantages to lowering the car? If not then I probably won't do it.
nghiars Apr 5, 2007 09:42 PM
lowered cars will handle better cuz they have a lower center of gravity
ron4row2 Apr 6, 2007 08:56 AM
So, if I'm thinking of lowering the car with a set of Z springs or something would I be better off going with the 245/40/18 tires?
AthensBlueG Apr 6, 2007 08:59 AM
http://www.rims-n-tires.com/rt_specs.jsp
^^^Will answer your questions. Remember you have 8" rims up front and 8.5 rims in back with the OEM 18" rims
Don't forget to maintain a stagger to keep the VDC happy...you don't want the same height of tires all around.
ron4row2 Apr 6, 2007 11:20 AM
I'm putting these on a sedan. It was said in an earlier post that the rims were 8" all around coming off the coupe. Anyone sure if the rims are staggered or if they are the same? I don't think I'm going to stagger the sedan as I want to be able to rotate the tires.
redlude97 Apr 6, 2007 02:22 PM
OEM 18's are 8" all around as Gdubsedan stated earlier
Gdup35sedan Apr 6, 2007 02:24 PM
no they are not staggered wheels as i stated above. They are all 18x8 +30
If you are going to lower the car then you'll want to run a 245/40/18 or 235/45/18 all around.
-GP-
Homeslice Apr 11, 2007 11:32 PM
235/45/18 is not too common!
I also just bought 18's from a coupe to go on my 03.5 sedan. I will not be lowering it.
Should we be considering a staggered setup?
ron4row2 Apr 11, 2007 11:47 PM
Thanks. I'm going to go with the 245/40/18 and lower it with Z/Coupe springs.
labguy94 Mar 20, 2008 11:55 PM
Sorry to bring this thread back from the dead. In my seaching I wanted a definitive answer. I am considering buying coupe 18's for my '05 sedan. I heard in the past that the wheels are "keyed" so it can't be rotated... Is this true? I would be planning to run 245/40/18 when the tires wear out and would like to rotate tires (without dismounting them from the wheel). Thanks in advance for the help!
shmashmortion Mar 24, 2008 01:39 AM
That was the best website I've come across in a few weeks looking for right tire sizes I could use for an G35 coupe 6mt with 19's. Stock tires are front:225/40/19 and rear:245/40/19. Looks like you could have a direct fitment tire size 245/35/19, 255/35/19 safely for all season tires. There's a number of other sizes you could use also but that was one that came up automatically.
They have the Michelin's on there site but was interesting was I went on Goodyear's and saw they have the Eagle F1 all season tires for that size. Just thought I'd share this. Got a bit exited about seeing all season tires besides the Michelin's.
© 2026 MH Sub I, LLC dba Internet Brands
