You think 20's will fit
Old Dec 22, 2007 | 03:32 PM
jserman's Avatar
I found a set of rims I want there
20x8.5 +25 F
20x10 + 25 R
the problem is I have tanabe springs on my car and it's dropped 1.5in all the way around...
I am scared if I get 20's they will rub hard core and I don't want to role my fenders...
what you guys think?????
Old Dec 22, 2007 | 03:37 PM
06PlatinumG's Avatar
What size tires are you planing on running
Old Dec 22, 2007 | 03:40 PM
jserman's Avatar
not totally sure but probably
Front: 245/35/20
Rear: 275/30/20
I can change it up a bit if I need to make them fit
Old Dec 22, 2007 | 03:45 PM
With that tire size and offset you will be fine on the front and close on the back but shouldn't have to roll the fenders, your added negetive camber with that drop will help.
Old Dec 22, 2007 | 04:13 PM
Cost a G's Avatar
It should fit without much or any work at all. I have a set of 20x9.5+10 and 20x10.5+ 0 coming in, that will need a little bit of work.
Old Dec 22, 2007 | 04:38 PM
heyitzalex's Avatar
that should fit easily on a coupe, with little or no modification
Old Dec 22, 2007 | 04:56 PM
johnsonhuang's Avatar
****.. i rub all the time. i dont give a **** anymore... if u want to mod your car, deal with the consequences...
Old Dec 22, 2007 | 05:05 PM
jserman's Avatar
true true........ well maybe I will give it a try.....
Old Dec 27, 2007 | 05:35 PM
jserman's Avatar
OKAY guys.....I bought the rims now I need tires....do you think a 255/35 will rub up front?????
or should I just stick with the 245/35?????
Old Dec 27, 2007 | 05:54 PM
Cost a G's Avatar
255/35 may be a little wide for 8.5 The thicker sidewall may take away from your steering response. Just stick with 245s
Old Dec 27, 2007 | 05:56 PM
redlude97's Avatar
You have a "VIP" signature yet you buy a wimpy setup like that and don't want to roll your fenders?
Old Dec 27, 2007 | 06:00 PM
dream_G35's Avatar
ouch , relax ppl lol. GL on your set-up, post pics when your done
Old Dec 27, 2007 | 06:55 PM
jserman's Avatar
I know I know... this is a temp setup untill I can get what I want.....
plus I couldn't pass up the deal I got on the rims.... thanks for the input guys.....
time to order some tires.....
Old Jan 6, 2008 | 12:05 AM
jserman's Avatar
okay guys I am still stuck on tires......
#1 - 245/35 and 275/30
#2 - 255/30 and 285/30
the 1st setup id by far the cheapest but I want the best look and make sure I don't rub...to much...LOL
Old Jan 6, 2008 | 11:08 AM
amazing35's Avatar
255/30 285/30 great setup
