Pirelli 210 Snowtires
Anybody with Pirelli 210 snowtires have a problem with droning on the highway at certain speeds? Mine get so bad sometimes it sounds like the music I'm listening to is screwed up. I turn off the CD and relize it's the car.
04 Silverstone G35 Coupe |
Re: Pirelli 210 Snowtires
Nah i don't have that problem.
check your tire pressure. Dunno for sure if low tire press would cause this problem, but it just might. 2004 Twlight Blue/Willow 6mt Coupe. Bel Vector 985 Hardwired. Grounding Kit. Next Project: Carputer. |
Nope...no problems here. The only time I notice any noise with these tires is when I'm driving in the snow...you can hear the tires "biting" into the snow. I love these tires!!
'03 G35 C Prem Pkg, Navi, Aero, Performance Wheel & Tire Pkg |
No droning here in Detroit (i.e. beaucoup snow and horrible roads). Very pleased and recommend Pirelli 210 SnowSports 225/50/17 (fronts) & 235/50/17 (rears) maintained at 35psi.
----- '04 Coupe 5AT DG/G loaded w/o spoiler (3pc Aero), BSM, splash guards, Navi, Sirius, 18" perf pkg |
I have them too (17's). They are louder then the stock Pilots especially on the highway, but expected as they are winter tires.
What PSI are you guys running?
I had set my to 30 when it was cold outside. I picked 30 because I thought that was the spec for the coupe with 17" wheels. 04 Silverstone G35 Coupe |
No problems here. Smooth even at 100mph
2003 BLK/BLK 6-spd Injen clear corners |
This is what the guy at tirerack said.
If your car is rated for 35 PSI for the 18's (which the 6mt coupe is), then you need to KEEP 35 PSI for the 17's. Even if the 5AT coupe with 17" rims is 30 PSI, still keep the original PSI's of your 6mt (if that's what you have).. 2004 Twlight Blue/Willow 6mt Coupe. Bel Vector 985 Hardwired. Grounding Kit. Next Project: Carputer. |
Thats correct. Your not changing the amount of air the tire holds, just the shape of the air. The tire gets a bit narrower and a bit taller but holds the same amount of air.
