G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   Stock 19's Tire help Plz..... (https://g35driver.com/forums/wheels-tires/215431-stock-19s-tire-help-plz.html)
808G35001 Apr 16, 2008 01:30 AM
I've been SCOURING the boards looking for answers to what kind of tires to get for my 2005 G35 6MT. Tirerack seems to be the way to go, even though they ain't got shait in stock..... I'm in hawaii and discount tire and TDL? or something like that charge almost 3 times the amount for shipping that tirerack does.....
Is it better to do the 225/40/19 and 245/45/19's staggered OR
245/40/19 all around?
Thanks in advance for your help, I really appreciate it. The road noise from my stock tires are freaking killing me! But on the bright side I got almost 21K miles out of them.
redlude97 Apr 16, 2008 01:33 AM
why wouldn't you use a 245/40/19 in the rear?
Beebo Apr 16, 2008 01:47 AM
^+1
but anyway i have 245/40/19 front and rear on my stock 19's with no problems at all...
808G35001 Apr 16, 2008 02:08 AM
Phat! Thanks for replying man! hmm maybe 245's all around are in my future afterall...
808G35001 Apr 16, 2008 02:09 AM
stocks came w/245/45/19's in the rear
redlude97 Apr 16, 2008 02:10 AM
I would recommend 245/35/19 front and 245/40/19 rear is you want to run the same widths all around. There is no point in running the same sized tires all around anyways because you can't rotate due to the different wheel widths front and rear. The VDC can also have issues with changing the stock height stagger
redlude97 Apr 16, 2008 02:11 AM
Stock is 245/40/19, not 245/45/19
808G35001 Apr 16, 2008 02:26 AM
really? stock for you, maybe stock in hawaii is different. I didn't change my tires, and thats how they is....
redlude97 Apr 16, 2008 02:28 AM
It is the same everywhere
Idyfohu Apr 16, 2008 03:38 AM
What he said.
And yes, the stock tires sizes are the same regardless of location. 245/40/19 in the rear.
Jeff92se Apr 16, 2008 12:56 PM
From what I read, if you keep the stagger within 5%, you "should" be okay. Or what ever % diff the oem stagger is, that should be maintained.
808G35001 Apr 16, 2008 04:03 PM
why are you guys telling me what stock is? Did my dealer change the tires after he got the car in? seriously.....
Jeff92se Apr 16, 2008 04:04 PM
Then the dealer put on the wrong sized tire for the front.
BlueDevilBAMF Apr 16, 2008 04:17 PM
Yeah stock is 225/40/19 front and 245/40/19 rear Bridgestone Potenza RE050A.
What tires do you have?
Initial-G Apr 16, 2008 04:18 PM
245/35/19 and 255/40/19 here. No problems although my rears are pretty tall compared to fronts
© 2026 MH Sub I, LLC dba Internet Brands
