03 Sedan rims won't fit 03 coupe?
I bought my G-coupe with aftermarket rims on it and I wanted to put stockers back on. I picked up a set of stock sedan premium six-spokes, the same style that the coupe comes with, and lo and behold they won't fit. Seems the back of the wheel hasn't got a large enough hole to fit around the hub and line up flush.
Am I out of luck completely or they just not interchangeable? This is a real kick in the nuts after getting and mounting tires and everything
They should fit, maybe you forgot to remove your hubcentric rings for your aftermarket wheels. BTW, the sedan version of the 17" wheels is not the same, not even close. They are 17x7+45 and will be horribly sunken in. I know because I use them for my winter wheels
FS[Canada]: 16" Ronal Rims with 205 65R16 Michelin X-Ice
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
