20in iforged and eibach's
I recently ordered 20in wheels off the iforged group buy, I was wondering if im going to get any rubbing or damage from the eibach's with 20's. Should I keep them on? does anyone have a pic of 20's with a lowered coupe?
03' G35c, CB, fully loaded w/ Nismo Spoiler... |
Re: 20in iforged and eibach's
it all depends on your offsets and tire sizes
i LIKE SEE TO
2005 g35 COUPE comming soon |
do a search for Joenismo's car he has 20" iForged with eibach, if i recall he said he had minor rubbing on rear driver side but he is running 285/30/20 if you run a 275/30/20 you should be able to get away without any rubbing as long as the offset are correct, this is most important factor to determine if your tires rub
I think Joenismo's alignment might be off, I was rubbing before my alignment and I'm lower then his car. This is if he used iforged's offsets. I'm using 285 rears as well
2003 G35 Coupe 6mt Diamond Graphite AIM= bkchang79 |
| All times are GMT -4. The time now is 08:05 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
