IF YOU HAVE S-TECH's ON YOUR G, POST PIC!
Thank you. I have a DG Coupe and I am considering lowering my car. Please post your pics of your G on Tein S-Tech's. Thanks again.
2 G or NOT 2 G, there is no question! https://g35driver.com/rides/spec/pix...1082757935.jpg |
Re: IF YOU HAVE S-TECH's ON YOUR G, POST PIC!
Here's mine for you.
<font color=green>04 G35C 6MT/Navi/Z-T/JWT/Tein S/RH C4 19x9/19x10.5/CC</font color=green> 248058-pics 130.jpg |
good post randy... the s-tech look just right... but the spring rate is high.. how stiff is the ride you guys? eibach has a much lower spring rate so it should feel closer to the stock suspension
04 6MT Coupe 35% Madico smoke tint /CF Hood /Injen Cat-back https://g35driver.com/rides/spec/pix...1081622188.jpg |
Sick, did you use the stock shocks? I'm assuming you had the sport package?
gixxer, did you use the stock shocks?
here's my contribution. both sick and i have stock shocks. i like the spring rates on the teins because it handles better. but of course you sacrifice comfort, which isn't much of a difference from the stockers. only bad thing is, you better open your wallet wider for some camber kits.
https://members.dslextreme.com/users...mages/flex.JPG |
All coupes have the same shock's. Only the sedan has a sport of non sport suspension. Be thankfull their is not such a thing, the oem shock's allow enough weight transfering as is.
Oem coupe spring rates are 314/342 Tein S-tech rates are 358/274 R+14% R-18% Transfers +32% to front Tein H-tech 324/263 F+ 5% R-22% Transfers +27% to front Eibach coupe springs *229/*337 front *274/*463 rear *first number is the softer initial progressive rate the second number is the higher final rate. Tein springs are progressive in the front linear rear and they do not tell us the softer inital rate, only the peak rate info is given by Tein. "All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.” Edmund Burke G35 6mt |
Yeah I'm still using the stock shocks but will be replacing them with something better in the near future.
Hers is mine with S Tech and stock shocks. Hopefully rims will be coming my way soon.
https://g35driver.com/rides/spec/pix...1070918097.jpg <font color=blue>04 CB COUPE / WILLOW / PREM PACK</font color=blue> 248227-IM000160.jpg |
kinetix racing has the front and rear camber kits plus rear toe adjustments for under $800.
you better open your wallet wider for some camber kits. <hr></blockquote> Can you elaborate? How much are you talking? 2 G or NOT 2 G, there is no question! https://g35driver.com/rides/spec/pix...1082757935.jpg |
I swore I read in another post that you don't need a camber kit with the S-techs or maybe it was the H-techs. [img]/w3timages/icons/crazy.gif[/img]
http://www.sinurgy.com/alice.jpg R.I.P. Pat Tillman 1976 - 2004 |
you don't "need" them, but the camber is definitely negatively increased. springs are cheap, tires are not. so expect to pony up at least 4-8x as much for the correction. youre a show team iirc, so i would think you would go with the nice shiny/expensive ones [img]/w3timages/icons/tongue.gif[/img]. saves you the hassle of going to the shop a few thousand miles earlier to swap out them tires.
Gsedan35,
From the specs you posted, it looks like the Eibach springs are stiffer then the Tein S-spec springs in the rear? Is that correct? G35 coupe 6spd Twilight Blue/Tan Fully Optioned Nismo CAI |
| All times are GMT -4. The time now is 07:18 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
