I've narrowed it down to two....
Guest
Posts: n/a
I've narrowed my possible 19" wheel selections down. It's between Work Euroline KH and Volk SF Challenge (see pics). What do you think?? If you notice your car in the pics, I think they are both awesome! The Volk's are merc. silver right? What is the finish on the Work KH?? Thanks!!......
Guest
Posts: n/a
Re: I've narrowed it down to two....
I say #1, because I have #2s. They both look good.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Russ
Black 6MT Coupe
Jax, FL
Guest
Posts: n/a
Of those two, I like the SF Challenge. If you like those Work wheels, get the Termist TS1 Reloaded instead of the KHs. The Termists look similar but a lot better.
Guest
Posts: n/a
Russ....I was thinking of 8.5x19(f) and 9.5x19(r), with245/35 and 275/75. What size on your G?? What are the offsets? My car is lowered with Eibachs..Do you think I would have rubbing problems with the above combo?
I have the same sizes. 245/35, 275/35. 24mm front, 21mm rear, stock suspension. Another member here has the setup you're looking at. Same wheels, same offset as me, lowered with Eibachs, but I'm not sure of his tire sizes. The last time I talked to him his front camber was so far off he had to swap his tires after a few thousand miles. His name here is "Omi", drop him a PM.
Russ
Black 6MT Coupe
Jax, FL
Russ
Black 6MT Coupe
Jax, FL
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
