those with PIAA Super Rozza's..
do you need aftermarket lug nuts for these wheels or can the OEM suffice?
thanks in advance :DOMO: |
you should use aftermarket lugnuts, they are shaped different at the ends
:dunno: im still using oem
aftermarket is just easier and looks better.
mine came with new lugs in the piaa hardware kit along with the center caps and hub rings
| All times are GMT -4. The time now is 09:15 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
