Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#2477
Buddy of mine just did the exact same thing 225/35 to a 225/30. No problems so far, but you're taking off a could chunk of rubber so you're more prone to bends and wheel damage.
Roll the fender, don't bother trying to make wheels look good if you won't roll the fenders.
xxX9 +30 and xxX10 +43ish is a good place to start.
But roll the fenders, no point not to.
#2478
#2481
#2482
So im going for this setup:
XXR526s 20x9 front and 20x11 rear +15 all around.
Gdup35sedan has helped me figure out what i need to do in order to make these fit:
-Coilovers
-spc rear camber w/toe bolt to get the -5 camber needed to fit rear wheels&tires.
-225/30/20 front tires and 255/30/20 rear tires
I jus placed an order for bc coils with spc rear camber kit w/toe bolt, which are backordered by 2 weeks, so i wont get them maybe until 3 weeks from today.
Any other advice from other members on here would be greatly appreciated. Thanks.
-Coilovers
#2483
Will I be alright buying just about any 19" rims and putting them on my 2004 G35 Coupe without lowering/rolling/spacers to begin with, and then be able to figure out where I want to go from there later while having a drivable car?
For ex.: Can I fit the VarrsToen the ES 1.1.2 19x9.5 front +22 & 19x11 +25 back without any rolling/spacers/etc?
#2484
i just put on some 350z eibach sportlines and the car rides like **** now. the rear end is pretty rough and seems to bottom out.
Are 350z rear shocks shorter then g35? Meaning will they allow more travel with my shorter springs?
Also the rears are progressive now compared to my s-techs i had on there before. Does anyone know if this will make a difference? I could always put the s-techs back on the rear and mod the spring mount by cutting it down a bit to get the same drop
#2485
#2486
-Coilovers
-Coilovers
No, struts are the same length as far as I know.
I need to know the widths and offsets of the wheels in order to know if it will rub.
#2487
#2490
