Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#2899
Blain, do you know what kind of a stretch the Nitto NT5's are? The tire stretch list that I have doesn't state what the NT5 was. Trying to stick with something that stretches true or slightly smaller than true. My Extensa HP's won't last me another 2 weeks and I found a set of NT5's for $95 a piece locally.
Planning on a 225/35 on my 9.5 wheel.
#2900
the tire sizes are fine, but you can go more aggressive with reasonable camber - I'll get to that in a sec. -light/slightly mild stretch. the rear stretch will be a little more. but why is your rear camber so much? you have a front camber kit but no rear - or have you not got an alignment yet?
as I said before, you can go more aggressive. you could put on a 30mm spacer up front and run about -1.2 camber. I run 9.5 +2 which is 3 more mm aggressive than if you ran a 30mm spacer, and run -1.4. - for the rear, you could put on a 25mm too and run about -1.8, but with your current desired set up you would run around -1.4.
last thing I'll say is, with your current stretch and offsets, you will be able to run within oem specs for sure - if that's what you're aiming for. but you need to fix that camber, running that stretch in the rear with the amount of camber will look sloppy.
tldr; run 25 and 20mm spacers - your fitment will be a bit better.
#2901
#2902
#2903
I'm ordering my autocross-only setup from Tire Rack and decided on Enkei RPF1's in 17x8 but from all my research, everyone runs +35 offset with them in that size, but Tire Rack recommends +45. I imagine that's because it'll be closest to stock, but If +35 will get me more flush without any poke, I'd rather do that. I don't have a BBK so clearance shouldn't be a problem either way I don't think. Which offset do I want for autocross use, and why?
In case it's relevant, I'm mounting 245/45/17 Dunlop Direzza Star Spec's on them which should be pretty square.
Thanks guys!
Thanks guys!
#2905
#2906
#2907
Ok, well with the 8.5 front it makes it a little tougher since the 245 is basically maxing out the width of that wheel. But still doable.
You have at least an inch up front so you could start with a 25mm spacer there and pull the fender liner screws out, the rear really depends on how much camber the car has out back.
Have you already rolled the rear fenders?
#2908
you have your offset terms mixed up. lower the offset(number), the further out it is. higher the offset the more sunk it is. people are right by running +35 over +42 for aesthetics.
#2909
Thanks guys!
Thanks guys!
Sedan dude.
